ADODB Connection
ADODB Connection
ADODB Connection
I am writing a macro for excel that will retrieve some data from an access database but am having some difficulty with the connection code.
What is supposed to happen is a connection is made when the worksbook is opened and sets a global variable which is used when the selection changes.  The problem I get is that when I change selection on a
sheet I get an error here:
rs.Open selectQuery, cn, adOpenDynamic, , adCmdText
saying:
"The connection cannot be used to perform this operation.  It is either closed or invalid in theis context"
looking at the global connection variable, it does appear to be active
This is the code I have so far:
Const databaseLocation As String = "C:\XP.mdb"
Public cn As ADODB.Connection
Private Sub Workbook_BeforeClose(Cancel As Boolean)
    'Clean up!!
    cn.Close
    Set cn = Nothing
End Sub
Private Sub Workbook_Open()
    Dim conn As ADODB.Connection
    Dim strConn As String
    Set cn = New ADODB.Connection
    Debug.Print "Start opening connection to database " & Format(Now, "hh:mm:ss")
    'Create connection
    strConn = "Provider=Microsoft.ACE.OLEDB.12.0;Data Source=" & databaseLocation & ";Persist Security Info=False;"
    Set conn = New ADODB.Connection
    conn.Open strConn
    Debug.Print "Finished opening connection to database " & Format(Now, "hh:mm:ss")
    cn = conn
End Sub
Private Sub Workbook_SheetSelectionChange(ByVal Sh As Object, ByVal Target As Range)
    Dim rs As ADODB.Recordset
    Dim selectQuery As String
    Dim selectedRow As Integer
    Dim selectedColumn As Integer
    'When a selection changes, update the row information only selected row is below header block
    'and is in column 1!!
    selectedRow = Target.Row
    selectedColumn = Target.Column
    If (Not (selectedRow >= 10) Or (Not (selectedColumn = 1))) Then
        Exit Sub
    End If
    'Create recordset query
    Debug.Print "Start opening recordset on database " & Format(Now, "hh:mm:ss")
    selectQuery = "SELECT tblParts.PartNo, tblParts.Description, tblParts.`Spares Category` FROM tblParts WHERE ((tblParts.PartNo) = '51-85-6')"
    Set rs = New ADODB.Recordset
    rs.CursorLocation = adUseClient
    Debug.Print "Finish opening recordset on database " & Format(Now, "hh:mm:ss")
    'Fill in the cell information from the returned data
    If (rs.RecordCount > 0) Then
        'There are records
        ActiveSheet.Cells(selectedRow, 1) = rs.Fields("PartNo")
    Else
        'There are no records for the given part number
        ActiveSheet.Cells(selectedRow, 3) = "Part Number not Recognised"
    End If
    'Clean up!!
    Set rs = Nothing
End Sub
Does anyone have any ideas?
RE: ADODB Connection
Hi maurelius,
Try this:
CODE
Set cn = conn
HTH
Todd
Ah! of all the obvious mistakes to make!!
Thanks Todd :)
