python - how to create a node set
Hi guys,
I'm reading the obd file to postprocess an analysis. The point is that, in my python routine, I would like to create a node set that I did not create in the preprocessing. In this way it is much easier when I extract the results from the fieldOutput. How is it possible?
thanks in advance for any advice.
bye bye
bye bye
RE: python - how to create a node set
To create new node set in odb file you can use constructor NodeSet(...) or NodeSetFromLabels(...).
Short example:
We want to create new set with nodes 5,10,12 into instance 'PART-1-1'. Pynthon syntax can be like this:
newSet=(5,10,12)
assembly=odbFile.rootAssembly
assembly.NodeSetFromLabels(name='myNewSet', nodeLabels=(('PART-1-1',newSet),))
Plase take a look into documentation for more details about the constructors.
Best Regards
thanks for your help. With your advice I solved the issue.
Bye bye
