Spline turns into flat segmented line
Howdie.
I have a datum curve I imported from an IGES file and it imported correctly as a smooth spline. But if I right-click it in the tree and select "Edit Definition", and bring up the editable .ibl file it got translated into, even if I don't edit anything and just resave it, it turns into a flat segmented curve. How can I prevent this from happening, as I need to edit the points data without destroying the smooth curve?
I am using W4
Thanks for any replies!
I am using W4
RE: Spline turns into flat segmented line
