Exporting a Faceted representation to JT file
I exported a large assembly (about 2000 components)to a jt file. Whith the faced representation Refeference Set. (The representation was created in the sub-assembly level...)
But when I opend it(in JT2GO), everything was green.
I tried to set the 2 possible display options to make the representation, but no sucess.
I need the original master model colors.
Someone can help me?
I´m using NX4
RE: Exporting a Faceted representation to JT file
If you modelled all the components in the same green colour and then changed it at the assembly level then I'm afraid that does not work. You actually have to go into the individual files and change the colours separately.
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
Hi hudson888, thanks!
I didn´t change the color at the assembly level. I need the individual colors.
At the assembly level all colors are the same as part level.
Assembly (exported file)
        ->Subassembly 1 (Representation is here)
                   -> component 1(green)
                   -> component 2(blue)
        ->Subassembly 2 (Representation is here)
                   -> component 3(green)
                   -> component 4(blue)
I tried to create the representation in some individual components, went to the assembly and export to jt, and works fine, with the right colors.
But I have 2000 components...
That seems odd since I can't seem to replicate the problem.
Best Regards
Hudson
www.jamb.com.au
