Support for catalytic converter
Hello folks! This is my first posting in EngTips.
I am in the automotive industry, and I have been tasked to design a catalytic converter mounted near the engine. I post in the piping forum because I feel the problem is somewhat related to what you guys are doing.
Consider the BMW V10 engine in this link: http://www .bmw-m5.in fo/images/ 2005-BMW-M 5-Engine-F lywhee.jpg
Notice the catalytic converters after the manifolds. They are supported by brackets to keep vibration stresses at an acceptable level. When designing a similar bracket in my application, I have three challenges:
1. Making sure the bracket fits due to tolerance buildup
2. Make it stiff enough to keep stresses down, and
3. To allow for thermal expansion.
I can solve the first two, but the thermal expansion seems tricky after some hand calculations. BMW must have solved this, but I can't really see how. Could the part with two screws between the bracket and the cat work as some sort of hinge? Or does the cat "slip" in its band clamp?
/regards Tancred
/regards Tancred
RE: Support for catalytic converter
Welcome to Eng Tips!
Since it has been a week and you haven't got any responses, may I suggest that you repost this in one of the automotive forums. I don't regularly post there, but forum78: Transmission, Driveline, Hybrid Drive engineering seems like it might be more what you need. If not that one, then forum108: Automotive Engineering other topics.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
