Rebar Deformation Shape
Does anyone know if there is a standard on the shape of deformations on rebar. The bar I have is in spec with regards to height just some of the deformations come to a point, like a triangle, and some dont.
RE: Rebar Deformation Shape
Have you checked ASTM A615?  That gives the requirements for the deformations.  In general though, it says the shapes from one to the other should be similar.
