ASME B31.1 or 31.3??
Greetings to all
Currently I am working on the design of a turbine generator. The gas fuel used in equipment will be gas. As the level of gas pressure is very low, is required for compressors (centrufugo or screw) to bring up the pressure indicated by the manufacturer of the turbine generator. Which rule applies to everything about the system of pipes in the area of compression of gas?.
Thank you for your reply.
pipeline
pipeline
RE: ASME B31.1 or 31.3??
