GFCI Receptacle for 250V?
For UL508A purposes, we typically run any non-UL listed devices on our 120V systems through a GFCI receptacle. We have a project where we are using 230V and our standard GFCI receptacle is only rated for 125V. I'm guessing I need a 6-20R receptacle configuration with a GFCI, but cannot find one, does anyone have any suggestions?
Thanks.
Thanks.
RE: GFCI Receptacle for 250V?
"Theory is when you know all and nothing works. Practice is when all works and nobody knows why. In this case we have put together theory and practice: nothing works... and nobody knows why! (Albert Einstein)
The normal considerations are still the best - proximity to water or hard grounds.
Keith Cress
Keith Cress
page 334 (H-17)
Not a receptacle, also not a breaker.
i would definitely be interested in it for future projects, do you have a link for these at all? we were on a short time frame for this project, so we went with a GFCI breaker, but i'd like to get info on your solution for next time...
Here's a link to Merlin Gerin's catalogue:
http:/
If their infernal website demands a registration then the catalogue number is MGLV5885. The RCBOs are on Page 1-18
Keith Cress
Good on ya,
Goober Dave
Keith Cress
The UL procedure in question is twofold. You must protect the unevaluated (non-UL listed) device with a LISTED GFCI, AND it must be fed from a Class 2 isolation transformer. Class 2 means that the total power is limited to 100W or less. For something 230V, that is essentially 0.43A maximum. So keep that in mind because if your non-listed device needs more than 430mA of power, you are SOL.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
I don't see the Class 2 requirement, just isolation -- and Class 2 can't be above 30 VRMS. Are you looking at appendix B, or am I missing something?
Holler!
Goober Dave
Thanks for the comeback, it's always great to hear how something gets resolved.
A star for your Hubbell find.
Good onya,
Goober Dave
