Scanner , fax machine, copier, printer hmmm
better to buy seperate ?? Can't image 4 machines . Nowadays there are programs to fax online. For a small business whats an engineer to do ????
thank you
thank you
RE: Scanner , fax machine, copier, printer hmmm
I bought an HP all-in-one because it was just a few bucks extra with a new used laptop. It works fine as a printer. It saves a trip when I need a scanner or a copier, so that's a bonus. I don't have pots here, so I don't know if the fax works, but I have no reason to believe it wouldn't.
... and if it dies, I can replace it for USD100 or less, so... what's to decide?
Cool part: When you change a print cartridge, you have to recalibrate the printer, for which purpose it generates a print, that you put in the scanner... and the machine does the rest.
Mike Halloran
Pembroke Pines, FL, USA
Chris
SolidWorks 09, CATIA V5
ctopher's home (updated Aug 5, 2008)
SolidWorks Legion
