UPPER ROOFING SHEARWALL
hello
two story house with roof deck, i have upper roof wall(pop out) for stair enclosure that is 4'-6" x 24'-0".
north side wall of stair enclosure has 3'-0" door, so i can't put shearwall(see attach pdf file).
i got plancheck for it. planchecker wants to see seismic calc for north side wall of stair enclosure.
how can i prove it?
i live in California
how can i prove it?
RE: UPPER ROOFING SHEARWALL
So I first would lead him to this view, and then prove by the if standing, standing calculations, he is wrong. If you do not have such calculations at hand some will need to be made, with proper checks on connections. And might be, depending upon your structure and framing, inspector is right and you may need some change for proper proof of compliance with the code.
Best wishees.
