Sloped Roofs: Unbraced Length Lb
I have a sloped roof modeled and axial loads are entering the members, which is ok, but this triggers the L/r<300 check to enter, which is also ok, but only if I was able to adjust the unbraced length of these members. I see an Lbtop and Lbbottom parameters that I can define but no Lbyy and Lbxx like in Risa 3d.
I'm assuming the roof deck will brace the beam about its weak axis, is there a way to tell the program this?
If not then I can go into the Design Module and bump the sizes down but this module doesn't flash the L/r<300 warning.
RE: Sloped Roofs: Unbraced Length Lb
Josh
Thanks Josh
