3sm allowable for IN625 from ASME Boiler and Pressure Vessel Code
Please can anyone give me the 3Sm (now Sps I believe) allowable from the ASME BPVC for Inconel 625 annealed sheet?  It's not in the 1986 edition.  Is it even in the later editions?
JE.
RE: 3sm allowable for IN625 from ASME Boiler and Pressure Vessel Code
JohnnyEnglish;
Why are you using the 1986 edition of the ASME B&PV Code? If you can get a more recent edition of the ASME B&PV Code, review UG-23. All if the information is there on how to calculate local discontinunity stresses from allowable stress S in Table 1B of Section II, Part D.
I'm using it because that's all I have.
Is IN625 in the latest version?  Can you give me the allowable for combined Primary and Secondary stresses please?  Or is it not a simple matter?
JohnnyEnglish;
Yes to your first question.
The stress intensity Sm is in Table 2B of Section II for Inconel 625 (UNS N06625). You need to know the service temperature to obtain a value. The value of 3Sm or Ssp is a calculated value.
