Export DWG in NX5
Export DWG in NX5
I am writing a macro to export a CGM, Import a CGM, Layer filter, Save, and then export a DWG to a user's c:\ directory. All is working fine axcept for one thing, I would like to be able to name the DWG file the same as the part name. Right now I have a dummy string called c:\test.dwg as the export file. Is there a way to code the part name into the line of th macro that says
ASK_ITEM 3407872 (1 STRN 0) = "C:test.dwg" !
RE: Export DWG in NX5
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
