What is the smallest size of AC motor ?
Hi all,
I'm trying to surf the internet seeking the smallest size of AC motor on the market. To be precise, I need 230Vac, 50Hz, max 1A, less then 0.1kW and of course, the smallest dimension/size of the motor itself. Could someone help me please ?
terwelu
terwelu
RE: What is the smallest size of AC motor ?
A Google Search for Sub-fractional motors yielded 4,370,000 hits
http://w
Might try here first
h
Ed
What speed are you looking for?
Actually, I'm testing one of the inverter product. As a tester, it would be convenience if I could have all components (controllers, inverter, motor, etc) in one place lying at my desk. I've seen other testing activities using big motor (in term of dimension) and it would required a big test rack.
I'm not familiar with "sub-fractional" motor. What's the difference with common AC motor ?
Fangas : thanks for the link. I'll try it !
Scotty : above 1000 rpm. However, dimension factor seems to be my focus.
terwelu
http://www.lafertna.com/frame.htm
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
