Built-Up Shapes in AISC
Hi Guys
I got a wierd question from our customer that where in the code of AISC that actually ALLOWES built-up shapes in the structure. In my case, the built-up shape is column and beam that welded from plates.(similar to plate girder).
Anyone knows where I can find a statement that I can use built-up shape in design?
I always think it's common sense that if rolled shape is not available, you have to use something builtup. But this customer is just strict on it.
RE: Built-Up Shapes in AISC
BA
On the other hand, if you're the fabricator and the design calls for rolled shapes, you can't willy-nilly substitute built-up shapes on your own say-so. You need to get the client's or designer's approval. But they should give it as long as you can demonstrate that your built-up piece has the same properties, that its connections can handle the requisite shear, etc.
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
Chapter D, Tension Members, Section D2, "Built-Up Members"; Chapter E2, Columns and Other Compression Members, Section E4 "Built-Up Members", Chapter F, Beams and Other Flexural Members, Section F7, "Built-Up Members"... And of Course Chapter G, Plate Girders... which are BUILT-UP from PLATES connected by welding or fasteners.
If that doesn't satisfy them, get another client.
