ESP with high capacity (1333 m3/h)
I am looking for an Electrical Submersible Pump with following specs. Can anyone suggest a manufacturer?
Discharge Flange : 14"/ 150#
Capacity : 1333 m3/h
Differential head : 97 mlc
Material : Super Duplex s.s.
Electric motor rating : 500 kW
Speed : 1480 rpm
Current characteristics : 3300 V / 50Hz / 3ph
Caisson min. inner Diameter : 925 mm
Total Pump Length : Approx. 27 m
Speed : 1480 rpm
RE: ESP with high capacity (1333 m3/h)
Pleuger (part of Flowserve) is also one of the 'names' in this niche.
