Dual Mass Flywheel > Conventional Flywheel for a Racing Application?
Hi there,
I'm considering Audi's 90-degree V6 for an upcoming competition car. The engine is equipped with a dual-mass flywheel in stock form. Though the aftermarket offers no lightweight and/or conventional alternatives for this motor (and indeed don't seem to support this motor much if at all), I'd be interested in investigating a custom solution.
My question is whether vibrations from the 90-degree six would be significant enough with a lightweight flywheel to compromise driveline reliability? The engine is likely to be solidly mounted, driving a rear-mounted transaxle via a torque tube. Thanks.
Thanks.
Thanks.
RE: Dual Mass Flywheel > Conventional Flywheel for a Racing Application?
If you don't have that kind of budget, it probably does.
Mike Halloran
Pembroke Pines, FL, USA
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
