Shear strength of Pin connection
I am checking the shear strength of a connection that is using a pin instead of a bolt.  Does it still fall under the criteria of a bolt, just design for it without including the threads? See attached calculation.  Thanks
RE: Shear strength of Pin connection
And there is no bolt tension and associated frictional resistance.
Mike McCann
MMC Engineering
you're using 1/2 Ftu as Fsu.
you're calculating the allowable shear per shear face (there's two of them reacting the applied load)
yeah, it's as though you're shearing the shank of a bolt.
there is also bolt bending to be considered (that's reasonably under the applied load)
Don't forget about bolt bearing checks.
