MSE wall estimating-
We are looking for someone to estimate  MSE style bridge approaches. A detailed estimate and scheduling are needed to draw comparison to a new approach system we are introducing to the market.
The bulk of the projects we are looking at are with FDOT-
Anyone interested?
RE: MSE wall estimating-
What type of approach system is that?
Are you referring to the new system?
Yes. Are you looking at making an installed cost comparison with conventional MSE panel type walls and your new system?  Cellucrete? Is this a new precast product?
In response to your first question,Yes.
With regards our product, the patent pending system is known as the Cellular Tilt Form it uses a combination of modified tilt wall panels in conjunction with Engineered Fill (Elastizell lightweight cellular concrete).  I will post a link to the website along with details and specs shortly.
Do you have an interest in the MSE estimating?
Cellucrete is the parent company of Modern Fill Systems LLC a JV between the Cellucrete and principals of C&C Pumping and Tilt-Up Plus
www.cellucrete.com
www.ccconcretepumping.com/index.html
www.tiltupplus.com
