Correct terminology for a doubler on the bottom of a wood beam
A few months back I came across a thread that discussed adding a doubler to the bottom of a wood beam that was undersized. The thread used a term for the doubler that I had never heard before so I bookmarked it somewhere. Wish I knew where. I also came across it in a book. Can't find that either.
It's tough getting old especially if you were already stupid.
Anyone out there know the correct term?
dpa
dpa
RE: Correct terminology for a doubler on the bottom of a wood beam
Dear EIT,
I have heard the term strongback used when a beam like arrangement is used to support a long heavy item at more than one point. It is used with heavy cranes when lifting pipe or long beams. It may apply to structures I'm not sure. I will search the sites for both terms.
Thanks guys
You are right strongback is also a structural term in addition to being a crane rigging term. Turns out a flitch plate is vertical and sandwitched between two wood beams and a strong back is on top (maybe also bottom?) of a beam.
Turns out strongback is what I am trying to do here since the structure is not accessible for adding a flitch plate.
Thanks again
Mike McCann
MMC Engineering
Mike McCann
MMC Engineering
Mike McCann
MMC Engineering
Download at:
http://ww
I think it all depends on what the member is and how are you utilizing it.
If it is a timber/steel beam placed below the existing beam you could call it a bolster beam, or a relieving beam.
If it is a timber or steel member fastened/bonded compositly to the bottom of the wood beam you could call it a strengthener or reinforcing plate.
I could swear I've heard 'cap' used to describe a half- length doubler welded to the bottom of a steel beam to stiffen it, but it's been a long time.
Mike Halloran
Pembroke Pines, FL, USA
(ht
Eg. for panels riddled with holes which aren't able to support their own weight when not vertical.
