Editing precision for BOM column
I am using Solidworks 2009 SP3.  I have inserted a BOM into a drawing that includes a WEIGHT column with parametrically linked values.  The values show up with their native precision, and in most cases it is two decimal places.  I want the values to appear on the drawing rounded to the nearest whole number.  Is there a way to specify this at the drawing level.  e.g. in excel I would simply format the column to have a lower precision.
The only solution that I can come up with so far is to individually edit each component's document precision.
Thank you for the help.
