Turning off the print dialogue box
How do I turn off the print dialogue box and edit print settings from the command line?
I wish to do this to set-up a button on my toolbar to print the current drawing as per previous plot, then save, change the settings back to dialogue box printing and close the current drawing.
RE: Turning off the print dialogue box
"_-plot"
ADT 2004
Hi gpraeroform,
If you're on an older version:
filedia 0
plot
filedia 1
HTH
Todd
Exxit was close.
In 2009, from the Command Line type "-plot" (no underscore).
Ralph
Structures Consulting
Northeast USA
Thanks for your assistance however "-plot" does not give me the same options as the plot dialogue box.
I wish to use the command line to perform the dialogue box function "Page Setup > Name > <Previous plot>" leaving all other settings as per the previous plot whatever they may have been.
But the "-plot" command just gives me the option to select a printer and change its setting .... no previous plot option.
Is there a simple way of doing this?
