DC closed loop Motor running with no speed reference.
Hello, Newbie on here but thought id give it a go..
I have a paper converting machine which is built up of sections, each is driven by an ABB 220A DC motor controlled via ABB DCS drive. Eachs ection of the mechine is sent a speed refernce via a fibre optic link, the speed reference is a master ref corrected dependent upon a dancer bar position. each motor drives steel/rubber rollers wieghing approx 2-3 tonne.
Under normal conditions all 4 DC motors ramp up and ramp down together very closely (so close a single ply of tissue can be passed through each section with out snappping)
My problem is that one of these sections motors, when ramping down is running on for longer than any other section even though the speed ref sent from the PLC appears to be a zero. in summary every section ramps down to a stop but one section runs on for approx 3-5 seconds.
I have attached two graphs, they are trends of the offending motor, one graph shows a good ramp down to 0m/min the other shows the fault when the motor runs on.
You'll notice that when the motor runs on the current rises more steeply as if the drive is over compensating.
My proposed theory....
If there was a mechanical failure casuing extra load on the motor, it would cause the motor to ramp down faster, as if being braked. The drive can see the motor is slowing to quickly and tries to compensae for this by applying some positive current/torque. but this current causes the motor to slow the ramp down too much and thus the motor takes longer to stop?
Red= motor speed
green= motor current
cyan = torque
blue = speed offset from ref
Any ideas anyone?? Fire away with the questions...
Red= motor speed
cyan = torque
RE: DC closed loop Motor running with no speed reference.
Could you, please, show again the offending drive with no offsets and a percent or p.u. scaling. A speed reference trace would be of great help.
Also, not everyone can figure out what ERR:OUT is. Is it speed controller output - or something else. Or is it SPC:OUT that is SPeedController output. If so, what is ERR:OUT?
Gunnar Englund
www.gke.org
Dave can you now see all three graphs?
