Update of boolean operations with solids ?
Hello all,
I have just created some bodies using boolean operations with other bodies (add) at the part and product level.
Well, when I make a change to the original bodies the resulting "boolean" bodies just do not update. I must delete and recreate them.
When I do the same using the "old way" (copy-pasting the sketches (with link) between bodies/parts) it works.
Has anybody got any clue? Thanks for any help!
BTW I'm using V5R8.
Friedrich
RE: Update of boolean operations with solids ?
Check tools/options in part designer if you have the "keep link with selected objects" turned on
Friedrich - are you using a legitimate copy of the software?  (as opposed to a downloaded version)
Just curious, based on your past posts.  Seems like you are "testing" a lot...
Catia Design|Catia Design News|Catia V5 blog
V5R8 (!!) should not be supported anymore
Eric N.
Main Menu/Edit/Links and then choose Load or something like that.
