Replacing circular stirrups with spiral
If the specification for stirrups is 9" O C what will be the pitch of 9 for the spiral replace the stirrups adequately?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Replacing circular stirrups with spiral
Mike McCann
MMC Engineering
Like hokie recommended, if it is a pile make sure they have and extra flat turn at the bottom for full development.
What concrete code do you use?
My reference was meant to say ACI 318-05 7.10.4.3
As hokie mentioned above, Cl 10.7.3.3.b
The spacing of ties or the pitch of a helix should not exceed the smaller of D (diameter/depth) and 15db for single bars.
Attention to shear in building columns has not been precisely a favorite theme; even the more used program for building structures here (CYPECAD, which is by now quite an achievement from the viewpoint of entry of data and detailing, so the production of plans) has started to contemplate the check some years ago (not many). This is not to say the EHE code was negligent, that was not; more a thing of practice.
This issue intrigued me, so I looked it up in ACI318-08. The way I read it, you are certainly correct for a "spirally reinforced column" to get the higher capacity. But I think you can use the provisions for a "tied column", with a spiral used as a "continuous circular tie" with the same pitch as the required tie spacing. See the Commentary to Paragraph 7.10.5.
You got it right, this what I was looking for, I have drilled piers with 4 #5 bars to be tied up at 9" OC -- the spiral with 9" (or less) pitch will do the job.
