Rigid Insulation to replace overburden in strip footing design
I am doing a strip footing design for a high load buildig structure is soils with very low soil bearing pressure. This new building is an add on to an existing building also with a strip footing. The original soils report only recommends either driven timber or steel piles and I can not do that because the existing building is finished in brick. Thus I want to use strip footings. However to negate the soil overburden on the acting on the footing and keep the footing a reasonable width (because of low soil bearing) I am thinking about replacing the soil overtop of the footing toes with rigid insulation up to about 1/2 meter below grade. Has anyone done this or seen this done before and if so what are some of the pro's & con's of this approach and any specific construction detailing to make it work? Thanks in advance for your assistance.
RE: Rigid Insulation to replace overburden in strip footing design
With the best will in the world, a strip footing on a low capacity formation will give you settlement problems.
Andy Machon
If the existing building is performing well on strip footings, why does your geotech. recommend piles? This disparity needs to be resolved. Maybe your issue is poor soils evaluation rather than poor soils.
With respect to the issue of differential settlement I am aware of this issue and am looking at jointing details that will allow the new building slide down with out impacting the other. I do not plan to tie the two buildings together so that the settlement of new structure will not impact the original.
The soils report is a good one and very detailed, just the soils are plain lousy!
If the building is a "high load" building as you state, then Ron's advice is correct and the weight of 0.5m of soil will be insignificant when compared with the load applied to the footing from the structure above. Although I have not designed such a structure, I know that polystyrene blocks have been used as low weight fill to the rear of bridge abutments due to its low compressibility and low weight. This may be one option you could consider.
Ron - good to speak to you again. I've been keeping quiet because as the site has grown a there are many more engineers offering advice. The site seems to cater mostly for US engineers and due to the time difference, by the time I visit the site the query has usually been addressed.
Good to see you're still offering "Top of the Range" advice. Best Regards
Andy Machon
The basement in the other building might say something about the shallow soils where the original designer just wanted them out of the way!
