125VDC Industrial type relay
I am looking for an industrial type relay, form c, 11 pin, 10A.
I checked potter brumfield but their relays are all rated 110Vdc max.
can anyone provide other brands? I am based in Alberta Canada
RE: 125VDC Industrial type relay
Buy a machine tool relay such as GE CR120B or equivalent.  They are available with 125V dc coil as a standard option.
http://www.geindustrial.com/cwc/Dispatcher?REQUEST=PRODUCTS&;pnlid=3&famid=32&catid=105&id=r-cr120
There are other vendors just as good or better - this was the only model number I had in my head.
"Theory is when you know all and nothing works. Practice is when all works and nobody knows why. In this case we have put together theory and practice: nothing works... and nobody knows why! (Albert Einstein)
Thanks dpc, waross.
I'll settle for the Allen Bradley relay.
I'm leaving for a couple of months holiday in a couple of days. We should try to get together for coffee at Timmy's in Thickwood when I get back. I'll probably be settled in in September.
Yours
Bill
Bill
"Why not the best?"
Jimmy Carter
