Real world European 3 phase power
I'm designing a 3-phase medical device for use in both the USA and in the EU. Normally it will be installed in hospitals and small clinics, some doctors offices. What is the range of voltage which I should specify for the incoming power? Is 360 VAC- 380 VAC good enough?
RE: Real world European 3 phase power
but you should design your systems for 0.4 kV and 50 Hz.
(German / Siemens standart)
On the other hand, UK energy level is different, pls check
bye
The transition towards a fixed 230/400V network should be achieved by 2003.
At this date, the plus/minus 10% tolerance (as quoted by jbartos) MIGHT (but probably will) be reviewed.
