Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...just the few hours I've spent on this site I have learned a lot. I can now implement features that will be very useful to my company, and some of those I never knew existed..."
Geography
Jimboliscious (Structural)
22 Jun 09 15:45
Has anybody modeled aircraft cable in RISA 3D?  What should I use for Allowable Yield Stress, Fy?  Would it be the breaking strength divided by the area?  Seems that would be the Fu tensile stress.
ishvaaag (Structural)
23 Jun 09 5:22
I think that more than a RISA question it is a "technical" question. So the cable will have some intent and more or less defined setup, and a someway defined envelope of loading hypotheses. So how you model such something will depend upon all these things. In some cases the design of cable structures involves iterative steps; this also can be used within RISA even for large deformations (geometrical nonlinearities) that of course are not the intent of a program like RISA, but you can approach it by such iterative procedures. Respect a single straight cable you have a tension-only element in RISA-3D; this will help you to not get some problems in analysis when using cables and a number of hypothesis. Yet for a special hypothesis that ensures tension you can model the cable, use P-Delta and have a nice approximation (for problems that not require the iterative process referred above) of the standing stress for the hypothesis. That you may want to compare it to a fraction of Fu or to Fy or whatever will depend of your technical intent. If you throw your cable-like element to RISA under a code, RISA will try to check it as per the code.
23 Jun 09 17:18
Thanks ishvaaaq.
oldrunner (Structural)
24 Jun 09 10:34
The USS Steel Wire Rope publication provides some values for cables.  They provide breaking strength and the E for structural steel.   There are also a number of design recommendations.
24 Jun 09 10:37
Correction:
The USS Steel Wire Rope publication provides some values for cables.  They provide breaking strength and the E for the cable.  Typically the E for cable is less than that of structural steel.   There are also a number of design recommendations.
24 Jun 09 11:58
Thanks Oldrunner.  This lead me to a similar post with the attached manual I believe you are speaking of.  Here's the thread to find the attachment.
thread507-239603: Elongation of Wire Rope
Close Box
Join Eng-Tips® Today!
Join Us             Close
