TAGS ON HOLE TABLES-I WANT LEADERS TO CONNECT TO EACH HOLE
I cant find this function that I use rarely.  I've a gazillion holes, and want the tags to have a leader line to the hole geometry.  I think I've done it before, but cant find it in the help screens.
RE: TAGS ON HOLE TABLES-I WANT LEADERS TO CONNECT TO EACH HOLE
Maybe the bit you're missing in the Help files is that you have to click on a Tag on the drawing to access the "Note Properties Manager" and set the leader style there (optional checkbox to apply to all)
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2009x64 SP3.0 Intel Core i7 2.94Ghz, 12Gb Ram, NVIDIA Quadro FX3700 Driver: 6.14.11.8246
SW2009x64 SP3.0 Intel Core 2 Duo 3.17Ghz, 8Gb Ram NVIDIA Quadro FX3700 Driver: 6.14.11.8246
1. Set your selection filter to select only Notes/Balloons
2. Box-select all hole tags at once
3. When the Property Manager comes up, hit the button to add leaders.
-handleman, CSWP (The new, easy test)
What handleman said, you have to do it to the text itself.  It's not a seperate hole table setting.
James Spisich
Design Engineer, CSWP
