Beam End Connectors
Beam End Connectors
Is there a British Standard or otherwise for Beam End Connectors, or do each fabricator have their own
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Beam End Connectors
The British steelwork association has a few publications on simple and moment connections for the ends of beams. you can view these publications on the web site attached
h
Just go to publications joints in steel construction simple or moment. If you detail your connections as per these manuals most fabricators will be happy enough.
When in doubt, just take the next small step.
