SS Tube Heat
SS Tube Heat
Could anyone can give me a details in terms of material composition and any supporting doc on:
A 213 TP 347 AND A271-347
It is true that A271-347 already discontinuity and been replaced with A213 TP347?
RE: SS Tube Heat
http://
A 271 was withdrawn in 1999, and replaced with A 213.
RE: SS Tube Heat
RE: SS Tube Heat
Did you have Hx tubes supplied under A 271 originally installed? If so, the A 213 tube material specification can be used in place of A 271 provided the same Grade or an upgraded tube material Grade is used.
RE: SS Tube Heat
Plymouth Tube
