Entering Admin mode issues
I enter the standard "cnext -env CATIA.V5R19.B19 -admin" in run and it errors out
"Requested Administrator Mode Failed
Variable CATReferenceSettingPath in your enviroment (CATIA_P3.V5R19.B19) is not set
Set the CATReferenceSettingPath Variable in your enviroment"
See attached for more info.
RE: Entering Admin mode issues
in the ENV txt file by default this value is empty.
h
MTM
CSWA Certified
ATC Certified
CAD Blog
http://mtm-cadtutorials.blogspot.com/
Profile
http://www.linkedin.com/in/mtmcad
It is not finding the path to your reference settings for any number of reasons. It may be that you have not defined them, or it may be that the drive or path that you are pointing to is not connected. (be careful of pointing reference settings to a removable drive)
Catia Design|Catia Design News|Catia V5 blog
