Computer Will not display results
I have not been able to display the results i obtain in a simulation study. I am useing Solidworks 2009 SP3 and have a ATI FireGL 5200 graphics card with 3GB of ram. This should be more then enough to display my results. I can successfully run the simulation and once the results are calculated the window where i see my assembly locks up. I can still use solid works it just seems unable to display my results for some reason. I can see extremly simple resuls ex. block that has a force on 1 end and is restrained on the other. I am just unable to see anything more complicated then that. I am currently trying to analyze an octogon with a block in the middle and the octogon is restrained on 1 side and the block in the middle has a force on it.
I think there is a problem with the graphics card but dont know for sure.
any help would be appriciated
RE: Computer Will not display results
Other than that without more info I have no idea what might be wrong. Perhaps make sure that your video driver and direct x versions are current.
