Circled leader text
Circled leader text
Try this again. Got a good answer before but did not fit question.
I want to use leader text and have whatever I type encircled with a balloon. The old 2d autocad did this with a symbol.
To forestall one wrong solution the autodesk balloon only works with the BOM and so is clunky. Great if bom matches what you are point to but if not... also can't copy a bom balloon.
Mark
Mark
RE: Circled leader text
Like attached.
Done with Welding Symbol
Here is an example of what I need to do. I'm being picky as I can do it but have to take several steps to do so (click balloon, pick where, create balloon, edit and override balloon, pick and edit arrowhead) and after all that I can't copy.
Hope you have a better way!!!
