How to make an editable stamp
I'm a structural engineer with a computer question.
I'm attempting to create a custom stamp in adobe. I have no problem creating the stamp. What I want to do is to be able to apply the stamp to a document, then edit the fields after it is on the document.
Is this possible?
Is this possible?
RE: How to make an editable stamp
If you make a text field, you have to manipulate its size to make it fit right and it just gets to be a pain.
I think I have it figured out. You can write script into the form field boxes. Does anyone know how to write java code to get it to ask for an input and then spit the input out? It should be pretty easy for anyone who knows anything about java. Unfortunately, I know nothing about that code. I took a C++ course in college, but that's obviously not java.
