Current ASME revision
Can anyone tell me what's the current revision of ASME, ASTM and MSS SP design standards?
I understand different standards were revised at different point of time but I'm not sure if standards I'm referring to now are of latest revision or old one's.
Thanks in advance.
Shashi
Thanks in advance.
Shashi
RE: Current ASME revision
Go the the ASME website, the ASTM website, for starters, and look it up yourself.
www.techstreet.com
The results will tell you if there any ammendments, if the year has been updated, ...........
Mike
If you are working for a reputable Company who has a Quality Department then revert to them. Any Quality department worth its salt should have a system to check and update (and let the engineering staff know) standards when they are issued and ammended. After all using up-to-date standards should be within the Quality remit of any Company.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
