Material Property for NL 610-10777-375
Hello ,
I was checking whether you guys have material properties for Nordam panels NL 610-10777-375 & NL 610-11233-375
Let me know guys if any one of you have allowables and source of same.
Please advice.
Kakalip
Please advice.
Kakalip
RE: Material Property for NL 610-10777-375
Wes C.
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
Long Beam Flexure, "L" Direction Skin Stress, psi
and Climbing Drum Peel in-lb/3-inch width
I have got some specs out of them for 610-10233-500 and similar but not the numbers you quoted, they are pretty slow at getting info to you in my experience.
If you were supplied with the actual panels I would be jumping up and down a bit more :)
