Method to design a big concentric reducer
Hi everbody
I hope someone can help me in this problem
I have a a carbon steel pipe that needs to be reduced
from 60" to 56", for gas Service 150#
Since is difficult to find on the market
this kind of Reducer, the only option
in urgency for me is to build it.
-Does anybody have a method to design and build in field
this fitting (sketch showing how many cuts, cut angles, length, etc.)?
(similar method found for mittered elbows?
-Is this practice allowed by code?
RE: Method to design a big concentric reducer
You need to comply with whatever local or State design codes exist.
Ok designing under that code in order
to get thickness,is OK.
But I´looking a method to build it at shop
(Shop sketches)
If the above sound a bit like what a design engineer likes to be paid to do, good - that makes 2 of us.
As btrueblood says either do the investigation into fabricators capabilities in your area and prepare the design documentation(incl drawings, material specs, weld information NDT requirements) yourself or pay a competent pressure systems engineers to do the necessary work.
Sure, I have not explained clearly the point.
The case:
In the field, we need to connect two pipes
one 60" to other 56", so we need a reducer.
Is process gas 150# 160 Degrees Farenheit.
the thickness is 0.75"
With the unavailability for such reducers
with my providers.
Can this be made in the field?
I mean, to have a pipe, make longitudinal cuts around
then to joined them, welded and thats all.
If can be done with mittered elbows, why can´t be done with reducers?
How is solved a case like this in industry?
C2it has already indicated which Code may be used to "design" the reducer. The reducer itself must be formed by rolling plate of required thickness (taking rolling tolerances into consideration) and butt welding probably two horizontal seams to connect the two rolled sections together to form the cone.
What you said sound OK.
So the way I thought is not the usual way
Formed from a piece of pipe?
Sorry I´m newbie as a Mech designer
In 'the old days' they didn't care much about codes and standards,
they used their calculations, common sense and workmanship.
I think You have a great idea to make cuts at the end and taper it and weld it.
When it's properly done(and it's only a 150# system),it's okee.
Greetings
