trouble importing manning's n values from arcmap via hec-georas
I'm using HEC-GeoRAS 4.1.1 and ArcGIS 9.3 sp1.
Using HEC-GeoRAS, I am able to create a Manning table for Manning's n values that appears to be correct. I select this table in the Layer Setup and extract the GIS data, but it is not included when I import this data into HEC-RAS.
Any help would be greatly appreciated.
RE: trouble importing manning's n values from arcmap via hec-georas
