ASME CODE STAMPS REQUIRED
To assemble a cast iron sectional boiler, is a ASME stamp required. What is an A stamp ( Assembly of Power Boiler) used for.
RE: ASME CODE STAMPS REQUIRED
An "A" Stamp is an assemblers stamp, but this is only found in ASME Sec I, Power Boilers.  Cast Iron sectionals are cover in Section IV.  Per HG-534, Field-Assembled Cast Iron boilers do not require an A stamp.  However, the installer is still required to do the final hydrostatic test as directed by the manufacturer.
will require the H stamp CI or H2 as the AI will witness the Hydro.
genblr
not oly that: the candidate will have a field endorsement on the authorization stamp
