SW Explorer custom property label
In SW Explorer I would like to know how to make the Description custom prop of the part as a label. (By label I mean the column headers in the right side windows: Name, Size, Type, Date Modified, etc.)
In Options-->Label tab you will see, at the bottom, "Choose 1 custom property to display". The box is grayed out. I found this in the help:
"The list is created from the properties created by the vault administrator on the Properties tab of the VaultAdmin tool."
I'm not using PDM. All I want is the ability to create a label from the Description custom property of the part or assembly. Is this not possible? Thanks in advance.
RE: SW Explorer custom property label
In SW Explorer I only have Local, References/Where Used, Add-ins and Search tabs.
It sounds like that option is only available if the PDM Vailt is used.
dsgnr1
Version of SolidWorks: 2009
SolidWorks Sercive Pack:sp3
Operating System & Service Pack: winxp pro v5.1 (sp2)
Graphics Card and Driver version: Nvidia Quadro fx540, 9.1.3.6
Amount of installed RAM: 3GB
Virtual Memory settings: APPS, total paging = 1024mb
CPU Type & Speed: intel pent 4 / cpu 3.00GHz
