Use of UW 16 f 3 a for small nozzles
Is there a calculation option available in Compress that will allow small nozzles meeting the criteria of (UW 16 f 3 a) to use an external fillet attachment weld only?
RE: Use of UW 16 f 3 a for small nozzles
From the nozzle menu select "Type 5". Click the "Standard Size Look-Up" button, then click the "Threaded Coupling" button.
