[b]Live load for PV solar panels[/b]
Wondering what should be the appropriate live load to use to design a ground mounted support for the PV panels (about 6' above grade). I'm leaning toward just using whatever I can generate from ASCE 7-05 wind pressure projecting into the panels. The only question is what table or figure I should be using from 7-05.
How about for PV panels mounted on covered parking structure (without the roof steel deck), where the panels are the one that actually provide the shade? Should it be subject to the same roof live load as the regular parking structure(no PV)? Thanks.
RE: [b]Live load for PV solar panels[/b]
As for the Parking structure, if the cells are acting as the 'roof' if you like then you correctly assumed they will have to be designed with the same live loading as the regular parking sructure.
