Spare parts for a digital protective relays
Dear All.
I would like ask you about your practic for order spare parts for a digital protective relays.
Not important companies.
What iare a rules, ideas, etc, maybe recomendations, documents
Thanks in advance.
Best Regards.
Slava
Thanks in advance.
Best Regards.
Slava
RE: Spare parts for a digital protective relays
Yep, you are right, possible relays, not parts ( for me full relay is spare parts too)
Q., how relays, for extreme cases, whole range is difficult and not so cheaper.
Some plants try to standardize as much as possible, even that means applying a relay that has many more functions than will be used for a particular application. Such as using a Multilin SR-750 or SEL-351 for all overcurrent relaying applications, although they are overkill for many of the applications. This has a lot of advantages that can make up for the added cost of the relay.
"Theory is when you know all and nothing works. Practice is when all works and nobody knows why. In this case we have put together theory and practice: nothing works... and nobody knows why! (Albert Einstein)
Good points.
Next point, one relay ( each type) per SS, power plant or per 100 relays of same type?
Best Regards.
Slava
Spare relays for most used applications.
