Convert AutoLisp math to standard systax
I need to convert several hundred lines of AutoLisp math formulas to standard math syntax to use in another programming language.  Is there a conversion program that does this?
RE: Convert AutoLisp math to standard systax
What's not "standard" about (/ (+ 2 3) 6.0)   :)
I doubt you'll find a converter, as there could be many possible desired formats
@carlb
You've got one too many closing parantheses!
Your code won't compile.
