Compressive Strength of Concrete Volumetric Base
Dear All,
What is the maximum cylindrical compressive strength that can be achieved, basing on volumetric mix of concrete as follows.
1. 1:2:4
2. 1:1.5:3
3. 1:4:8
I would seek your expert opinion on if it is possible to achieve 3000 Psi cylinder strength using OPC and mix ratio (1:2:4) and 3750 Psi cylinder strength using OPC and mix ratio being (1:1.5:3) with out using any construction chemicals additionally.
Engr. Shakeel Ahsan
Director Engineering
CMEC - Pakistan
