adhesive design for skin to honeycomb core bonding in sandwich structu
Hi
I have to select an adhesive for skin to honeycomb bonding.
I have been thinking of comparing the lamina FEA stess results with adhesive mechanical properties.
I wonder if that is the right way to go ahead.
Do you know whether there is a standard calculation procedure to predict the stress applied on the interface between the lamina and the core?
Do you know any paper or book references about that?
RE: adhesive design for skin to honeycomb core bonding in sandwich structu
For sandwich panel design see the Hexcel document at
h
and the Diab one at
http://w
are good basic references. See also
htt
for additional background and
http://
The latter is the modern version of their classic TSB 120 document.
Zenkert "An Introduction to Sandwich Construction" is probably about as standard a reference as you'll get in a textbook, though Tom Bitzer's "Honeycomb Technology" is also referenced in the Hexcel document. An earlier book by Howard G. Allen "Analysis and Design of Structural Sandwich Panels" is also very worthy, if out of print.
