SKIN Frinction Help needed
I have the following Data.
Borehole in rock with visible serpentinite presense, other kinds of rock exist as well drill refusal at 5 ft.
The sample depth is 2ft to 2.5 ft
(Blows per ft*0.63/Blows per ft) is given as >50 (blow counts obtained from Modified California Sampler were multiplied by 0.63 to correlate with Terzaghi values(Martin&Lew,1999)
Dry Density 75.5 pcf
Moisture Content 31.3%
Angle of Internal friction (phi) 35
Unit Cohesion 0.2 Kilo Newton psf)
No Plasticity.
The design of the pier is recommended with 750 pfs skin frinction.
Now is not this too low for such a smaple? I did not see the calculation and the reason behind this number but I think it is too low.
No Plasticity.
RE: SKIN Frinction Help needed
