Unable to include from some ref planes
Hi all,
I've got a strange problem where I can't include a part ref plane edge onto an assembly sketch.
I am able to include the edges of 2 of the planes - one parallel to sketch plane, the other at 90deg, but not the the third plane, and that's the one I want.
Solid Edge V20, SP14
Any ideas?
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
RE: Unable to include from some ref planes
If i understand youre question, you can't include the 3rd plane cause youre workin on that plane. Understand???
Solid Edge V20
Hi Cadman,
No, this is really a strange one.
Normally you don't see the edges of the plane that is parallel to the sketch plane (the one I'm working on), but you see the 'cross' formed by the 2 other orthogonal planes.
I can locate and include the edges of the parallel plane (thus creating a square) and ONE of the orthogonal ones (thus getting a line) but not the other othogonal plane -  and sod's operates here because it's always the one I want that I can't locate.
bc.
Quadro FX4600.
...and just to clarify, the sketch is in an assembly and I am trying to include from part planes.
bc.
Quadro FX4600.
are the parts activated?
Yes, all parts are activated.
Part edge locate is ON
Peer part edge locate is ON
Silhouette edge locate is ON
Just to repeat - I CAN include some planes but not others within the SAME part.
bc.
Quadro FX4600.
sounds like a problem for GTAC then.
